Home > Maintenance & Mods (L405) > L405 DRL
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
L405 DRL
The front DRL's work fine, but how can I get the rear lights to come on at the same time. I like having both front & rear lights on during the day. I had this function on my previous sport. The rear lights, from memory came on when drive was selected. At present both front & rear lights illuminate when the door is opened. Start engine, front Drl comes on but rear lights are off. 2021 RR Fifty
Post #713720 10th Mar 2025 6:38pm
i want the same as you..twas available on the 2015/2016 models when landrover thought it was going to be law but this did not happen so they reverted to front drls only from then..
i've researched it and it seems that it cant be done...i've contacted Pat at GAP re this to see if the iidtool can change the CCF but i havnt had a reply yet... ... - .- -.
Post #713737 10th Mar 2025 9:24pm
chicb
Big Cry Let me know if you get an answer Sad
Post #713740 10th Mar 2025 9:47pm
I cheated when I had my first 405 and simply put a jumper fuse holder wire thingy with a blocking diode in it between the DRL fuse and the rear light fuse/s.
The diode was in there to stop the rear lights powering up the front DRL's when you actually switch the lights on...
And they still work today! (as my wife now owns it) Thumbs Up
Post #713748 11th Mar 2025 12:25am
thats clever Craig...i wish i know how to do that..
can you get powerfuluk to do a kit? Very Happy ... - .- -.
Post #713760 11th Mar 2025 7:58am
Can you solder Stan?
Post #713763 11th Mar 2025 9:20am
i can Thumbs Up
but, mines got a LR warranty and i'm not sure whether i should do this kind of mod... Neutral
can you not do this via the iidtool? ... - .- -.
Post #713764 11th Mar 2025 9:26am
I don't think Patrick ever did this?
Post #713774 11th Mar 2025 10:27am
Could there be a CCF for later cars Stan? Ive seen some working on late cars... I have a 20/21 in now with rear DRL working
Post #713775 11th Mar 2025 10:28am
GraemeS
Australia
I don't think my MY21's front DRLs are bright enough for open road use in the Australian sunlight so I'm switching on the headlights when I remember. I had my L322's headlights set as DRLs.
The LED headlights on my '21 Vogue SE aren't a patch on the LED bi-xenons and HID high-beam fill-ins on my L322. High beam output is weak, the band has inadequate height for undulating roads and has inadequate width. I'll have to do something to improve high-beam light.
Post #713777 11th Mar 2025 10:47am
Try changing the CCF to Scandinavian Graeme as they have to have 55w front lamps on as standard 24hrs... IE brighter than DRL's Thumbs Up
Post #713780 11th Mar 2025 10:50am
chicb
Idiots guide would be good. I'm willing to give it a go Whistle
Post #713781 11th Mar 2025 10:56am
GraemeS
Australia
Thanks Craig, that's what I had my L322 set to, but I suspect that I need a G4 IIDtool to do much with my MY21. I was suprised that my G3 read and cleared faults from at least some ecus but it isn't licensed to the L405 so can't even try to change CF settings.
Post #713782 11th Mar 2025 11:07am
thats interesting re the 20/21 Craig....so there must be a setting somewhere in the CCF... ... - .- -.
Post #713786 11th Mar 2025 11:29am
Yes I’ve just double checked Stan and this one’s rear lights definitely come on with DRL. I’m sure it’s a CCF adjustment on 18+ 405’s sir… 🫶
Post #713808 11th Mar 2025 4:14pm
