Home > Technical (L405) > SDV8 Engine removal with torque converter attached?
911r44
Hello experts
I have a SDV8 with a damaged engine. The engine doesn't turn over, assuming it's a conrod or crank failure.
I plan to remove the engine and leave the transmission in place as I'll be working without a 4 post lift. I've been encouraged by the 'All I want for Christmas is a new engine' post by 4RRS. (Great post, thank you for the pictures)
The question - Has anyone removed the engine with the torque converter attached? As I can't rotate the engine I can't get to the torque converter bolts.
Thoughts much appreciated.
Post #713617 9th Mar 2025 8:21am
dhallworth
I've never done it on an SDV8 but I have on other cars.
In theory, as long as you have space in front of the engine to slide it forward the depth of the torque converter then you should be able to get it out.
The fun bit will be separating it from the flywheel.
Post #713651 9th Mar 2025 8:24pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Re: SDV8 Engine removal with torque converter attached?
911r44 wrote:
Hello experts
I think you'Ill struggle to pull the engine far enough forward to clear the torque convertor, remove the front diff and I'd say it would be do-able. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #713653 9th Mar 2025 8:46pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
There's a lot that can come away from the front of the engine bay, which would probably give space. Once you've removed the front bumper, the panel where the bonnet closes on to, the radiator and aircon condenser there's probably not much more in the way. You have to do a lot of this just to change the aircon condenser, and I guess removing the oil cooler, condenser, radiator/shrouds etc. is not that much more work.
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #713687 10th Mar 2025 10:40am
