![]() | Home > Technical (L405) > SDV8 Engine removal with torque converter attached? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3202 ![]() ![]() ![]() |
I've never done it on an SDV8 but I have on other cars.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 297 ![]() ![]() ![]() |
I think you'Ill struggle to pull the engine far enough forward to clear the torque convertor, remove the front diff and I'd say it would be do-able. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
There's a lot that can come away from the front of the engine bay, which would probably give space. Once you've removed the front bumper, the panel where the bonnet closes on to, the radiator and aircon condenser there's probably not much more in the way. You have to do a lot of this just to change the aircon condenser, and I guess removing the oil cooler, condenser, radiator/shrouds etc. is not that much more work.
