Home > Maintenance & Mods (L322) > Rear wiper fault
Danwilderspin
Rear wiper fault
So my rear wiper started squirting water into the cabin. Looked at a diy and it recommended a washer but it doesn’t look available now.. did anyone find a new source?
Anyway, I carried on with it without squirting just the wiper, but today it just stopped at 5oclock… any ideas if it’s salvageable? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #713365 5th Mar 2025 12:11pm
Danwilderspin
More on this - I pushed the blade up a bit and then it resets when the car is back on. If I try and use again it gets to the same place and stops until I push it and turn the car in again…
Any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #713431 6th Mar 2025 2:36pm
wayneg
If you search and read all the previous post on this subject you have two issues.1/ the water leak, 2/ the plastic gear. 1 causes 2 to strip. A BMW Mini wiper motor gear is a direct replacement. The shaft seal size will be in the old threads so should be a simple find on ebay/aliexpress etc 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #713467 7th Mar 2025 9:21am
