![]() | Home > Maintenance & Mods (L322) > Rear wiper fault |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
More on this - I pushed the blade up a bit and then it resets when the car is back on. If I try and use again it gets to the same place and stops until I push it and turn the car in again…
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
If you search and read all the previous post on this subject you have two issues.1/ the water leak, 2/ the plastic gear. 1 causes 2 to strip. A BMW Mini wiper motor gear is a direct replacement. The shaft seal size will be in the old threads so should be a simple find on ebay/aliexpress etc 2007 TDV8 VSE
