Home > Technical (L322) > Stuck 3rd Gear
Yep, that's the part, IIRC you can't dismantle it without wrecking it, it's plastic moulded around the small stat... If you remove it I guess you could try the whole thing but that means doing the job twice and trying to test it's flow while it's a lot hotter than hand hot...!! Pete
Post #713686 10th Mar 2025 10:37am
RRPhil
Some info. here : https://www.landyzone.co.uk/land-rover/200...ge.231195/
Phil
Post #713690 10th Mar 2025 11:11am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Thanks everyone.
Quick thought, is it possible to use an infrared thermometer on the pipes of the lower radiator/oil cooler supply Thermostat housing to see if the pipes to / from it are heating up? As I assume if it's hot one side feed, but not the other return, then that would prove there's an issue with the thermostat?
Or is that not possible?
Cheers Thumbs Up
Post #713691 10th Mar 2025 11:34am
batfink
Phil
That's a great right-up and I do love a lot of pictures
Post #713692 10th Mar 2025 11:51am
The manifold also heats up the fluid when it's cold so although you would get a difference in temp output it might be hard to decide which is which and whether it should be hot or cold...!! Pete
Post #713696 10th Mar 2025 12:50pm
batfink
Thanks Pete, I guess I'll buy the thermostat housing and then get a new oil cooler if that still doesn't drop the temp sufficiently. Thumbs Up
Post #713702 10th Mar 2025 1:15pm
batfink
Just to update the thread, as one of my pet peeves is when people don't let everyone know the outcome.
I changed the lower thermostat to the oil cooler, and replaced the oil cooler too. Transmission temperatures seemed to stay a few degrees lower than the engine temperature.
Now just did the oil change today after the previous high temperature, and it's changing nice and smooth. The oil looked good, just a darker brown rather than straw coloured and didn't smell of burnt oil at all, so hopefully the transmission didn't get hot for long.
One thing I'm wondering is if the temperature sensor is a bit duff, as before I changed the oil, I checked the oil pan temperature with an infrared thermometer and the oil pan temperature was 16.5c, but the diagnostic tool was showing 36.5c (20c difference). Every time I checked the diagnostic tool it was showing +20c over actual oil pan temperature.
Anyway will keep an eye on things and post again if any further updates.
Cheers Everyone
Post #716903 27th Apr 2025 4:11pm
