![]() | Home > Technical (L405) > Fuel tank shield cradle |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Actual if searching LR071011:
Dstew Member Since: 26 Dec 2020 Location: Kent Posts: 44 ![]() ![]() |
Thanks for your message.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
AFAIA they are not making any more, been on back order for ages...
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 513 ![]() ![]() ![]() |
snap been looking as well |
You would have to construct a tank protection that consists of two parts, then you wouldn't have to remove the cardan shaft. The exhaust is easy to remove. Here in Germany these parts have rusted through on almost all L494 + L405, and the authorized dealer always says: You are the first to have this...., since my entire circle of friends bought a Range Rover instead of a Cayenne because of my specialist knowledge, I'll see if something can be done, my wife has a large metal processing company with all the pressing tools. Stay tuned and will report back. (I repaired my protection with polyester). L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
Could you explain that a little more ? Did you replace the whole cradle or just a patch? V8 or else ... |
I completely removed the tank protection (built in 3/2017 with Ad Blue), sandblasted it in a box, removed the rust, treated it with FERTAN, sealed small holes, the size of a finger, with epoxy resin (2K) and fiberglass mat, cut the two drain holes open again, and then painted them black with HAMMERITE paint. It's amazing, a perfect 2017 L405 has just such a few rust spots, the rest is as good as new. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Ok - thanks, that makes sense V8 or else ... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I’ve had to get one for my 16 through LR been on back order for a couple of months but I’ve now got a delivery date. Mine has Adblue tho so will be different. There is nothing that can't be fixed with a hammer😜😜
