Home > Technical (L405) > Fuel tank shield cradle
Dstew
I need a fuel tank shield cradle for a 2016 L405 4.4 without adblue.
They appear to be like rocking horse Censored .
Any ideas?
David
Post #713282 4th Mar 2025 10:08am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Actual if searching LR071011:
https://www.lrdirect.com/lr071011-automatic-transmission
https://www.lrparts.net/lr054812-fuel-tank...-l494.html
Easy job if without AdBlue, the tank can stay in the car, only problem is to loosen the propshaft.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #713284 4th Mar 2025 10:20am
Dstew
Thanks for your message.
However on back order from Land Rover with no likely date.
Post #713286 4th Mar 2025 10:48am
AFAIA they are not making any more, been on back order for ages...
New, old stock do come up on ebay now and again... I had a search set up with the part number, you can have it email you if one comes on, sods law I bought second hand and a week later 4 came up for sale...
Or second hand and refurbish, I picked up a second hand one with only surface rust, shot blast and hot dip and I shouldn't have to revisit that job again... Thumbs Up
There is a company making pattern ones for the Evoke, it seems all late Range Rovers of any denomination are having the same problem, the Evoke ones don't fit a fatty but maybe they will make some soon...
You don't "Have" to change it, the mounting bolts hold the tank up as well, it doesn't need to be there, you could take it off or just leave it till you find another one...
Even if you go off road it would be pretty hard to knock a hole in the tank, if you did I think it would be the least of your worries.... Thumbs Up Pete
Post #713289 4th Mar 2025 12:20pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Re: Fuel tank shield cradle
Any ideas?
David
snap been looking as well
Post #713294 4th Mar 2025 2:57pm
Meerbusch
You would have to construct a tank protection that consists of two parts, then you wouldn't have to remove the cardan shaft. The exhaust is easy to remove. Here in Germany these parts have rusted through on almost all L494 + L405, and the authorized dealer always says: You are the first to have this...., since my entire circle of friends bought a Range Rover instead of a Cayenne because of my specialist knowledge, I'll see if something can be done, my wife has a large metal processing company with all the pressing tools. Stay tuned and will report back. (I repaired my protection with polyester). L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #713313 4th Mar 2025 6:04pm
fisha
Could you explain that a little more ? Did you replace the whole cradle or just a patch? V8 or else ...
Post #713351 5th Mar 2025 8:21am
Meerbusch
I completely removed the tank protection (built in 3/2017 with Ad Blue), sandblasted it in a box, removed the rust, treated it with FERTAN, sealed small holes, the size of a finger, with epoxy resin (2K) and fiberglass mat, cut the two drain holes open again, and then painted them black with HAMMERITE paint. It's amazing, a perfect 2017 L405 has just such a few rust spots, the rest is as good as new. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #713353 5th Mar 2025 9:53am
fisha
Ok - thanks, that makes sense V8 or else ...
Post #713366 5th Mar 2025 12:27pm
I’ve had to get one for my 16 through LR been on back order for a couple of months but I’ve now got a delivery date. Mine has Adblue tho so will be different. There is nothing that can't be fixed with a hammer😜😜
Post #713387 5th Mar 2025 7:09pm
