![]() | Home > Technical (L405) > Access mode |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
auto access setting is in the speedo dash menu..
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 202 ![]() ![]() |
Thanks Stan, so you can turn it off then ? |
yes you can... |
Great thanks again Stan |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 72 ![]() ![]() ![]() |
When I first got my L405, I also was about to de-select auto access height, thinking it was putting undue strain on the bags and unecccessary cycles on the compressor….but a wise friend countered “use it or lose it” , so I left it alone.
Yeah good idea, I just don't need it everytime,must wear the pump etc eventually though |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1648 ![]() ![]() ![]() |
Better than the pump seizing due to lack of use? |
Maybe, still think it would wear out quicker on the sort of journeys I do. But I will run it now and again |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 137 ![]() ![]() ![]() |
The pump won't seize through lack of use! Each time you have a different load in the vehicle it will inflate or deflate the system. I think it also drops down at motorway speed and rises again when you slow down.
Like it Chris , sounds good |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 173 ![]() ![]() ![]() |
This must be another feature that my bog standard base model doesn't have. I have to press the button every time and on the 90% of occasions when I forget, filthy looks are forthcoming from the passenger seat. It would be handy if it operated every time. Maybe I can select it using iiD. |
i think this feature came in on the facelifts [2017 onwards ] ... - .- -.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3214 ![]() ![]() ![]() |
Ive got it on my Nov 2015 (2016 MY) |
I checked the owners manual last night, and it definitely goes up and down of it's own accord depending on road speed, so the system will always be used even if you never adjust the height manually.
