Home > Maintenance & Mods (L405) > Window frame surrounds.
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Rather irritatingly I opened the driver's door under a low branch the other day and bent the end of the aluminium door frame trim, the gloss black finishing trim.
I attempted to bend it back but it has cracked the plastic coating in doing so.
Researching the part online it seems that it's Part Number LR034038.
Has anyone ever changed one?
If not my plan is to carefully attack my old one and hopefully that will give clues on how to fit the new one.
Thanks in advance.
https://www.fullfatrr.com/gallery/albums/u...G_9470.png
https://www.fullfatrr.com/gallery/albums/u...G_9469.png 2015 SDV8 L405
1996 TVR Griffith 500
Post #712749 25th Feb 2025 9:52am
Vogue
Yes these are a separate trim part and are replaceable - my drivers one was replaced by the main agent as they opened the door into something and bent the top corner. It was held on by clips from what I was told. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #712797 25th Feb 2025 7:37pm
Stick Legs
Perfect.
Thanks for that. 2015 SDV8 L405
Post #712801 25th Feb 2025 7:52pm
