Home > Maintenance & Mods (L405) > Long Pedal Travel
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Long Pedal Travel
In 2023 when I bought the car the pedal travel was fairly long and had some terrible crap pads + long overdue fluid renewal. This was done at my indie and resulted in a perfect brake system with lovely stuff but progressive pedal.
Just had new genuine LR brake flexis all round (part of these assemblies are hard lines) and picked it up after service. The brake pedal is very light and has a ridiculously long travel. Almost to the floor. The car brakes fine and you can modulate it still but it feels very wrong and not confidence inspiring.
Garage bled the system 3 times, including w/vac bleeder and once with pedal. I’ve inspected the brakes and N/S caliper bleed screw seemed to be a little wet but not leaky. Nipped it up as wasn’t 100% tight (although was 99% tight) - cannot see any other leaks and master cylinder is dry as a bone.
Garage seem stumped, I’m stumped. Where to go from here? Assuming this isn’t normal
Post #712513 22nd Feb 2025 4:25pm
See if you can get a higher pedal by pumping the pedal next time you brake, you don't have to do it fast or hard, just pump it 4-5 times and see if the pedal comes higher up.... If it does there is still air in the system so it will need bleeding properly... Pete
Post #712523 22nd Feb 2025 6:20pm
fisha
Did you bleed the 2 valves in the engine bay ? They are at the front of the offside strut … it’s a black metal box with the valves facing horizontally forward. Doing this made a difference for me in terms of travel. V8 or else ...
Post #712525 22nd Feb 2025 6:54pm
JamboM3
Right pumped the pedal and it made the most minimal difference, basically none. Which is odd! The pedal does not sink, or go further, it’s just the travel and relative lightness.
As for bleeding, my Tech did not use the valves I believe but apparently does have the right tool to do this via the box! (Also checked the WSM and it mentions this)
So will investigate!
Post #712549 22nd Feb 2025 10:35pm
Mikey
These can be an absolute nightmare to bleed. Some are fine first time, some are just a Censored
The best way seems to be, to unbolt the bottom caliper bolt, and swing up to 45 degrees, and bleed in that position Thumbs Up
Post #712564 23rd Feb 2025 7:29am
That's a good tip..... Thumbs Up Pete
Post #712582 23rd Feb 2025 11:32am
fisha
I will say though that I feel my L405 has a soft travel feel to it compared to my BMW and some other cars ... almost like over assistance, Rather than hitting a travel stop point on the pedal when they bite on the disc, against which you then put more pressure on a a stopped pedal, you keep traveling with the pedal as it increases the bite.
I replaced my rear caliper pistons and seals recently with a full flush and bleed all around . After bleeding, the travel felt markedly softer, longer but smoother than before ... but the performance is still there.
Its almost like when the brakes get older, dirtier, pistons start seizing and not moving as smoothly as they should, this creates resistance in the system which we equate to positive pedal feel. When you rebuild the brakes with a clean, fresh, well working setup, the resistance in the system drops ... making for a softer pedal feel ? i.e. you need less pressure to acheive the same bite cause the system is working better. V8 or else ...
Post #712610 23rd Feb 2025 2:38pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I gave up trying for a firmer pedal after fitting new flexys. I must've bled them umpteen times to no avail. Since then however, I've acquired an iid tool and a pressure bleeder so I'll try again when the weather warms up. A glutton for punishment, that's me.
Post #712625 23rd Feb 2025 6:41pm
JamboM3
My tech has agreed to re do the bleed to see if it makes a difference. It’s not scary and I have confidence in the car/brakes but whilst I can live with the softer feel the travel is just alarming, it’s not the worst but does not seem right as before it was relatively firm,
Will update on how it goes.
Post #712736 24th Feb 2025 11:44pm
