![]() | Home > Maintenance & Mods (L405) > Long Pedal Travel |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8552 ![]() ![]() ![]() |
See if you can get a higher pedal by pumping the pedal next time you brake, you don't have to do it fast or hard, just pump it 4-5 times and see if the pedal comes higher up.... If it does there is still air in the system so it will need bleeding properly... Pete
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
Did you bleed the 2 valves in the engine bay ? They are at the front of the offside strut … it’s a black metal box with the valves facing horizontally forward. Doing this made a difference for me in terms of travel. V8 or else ... |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 230 ![]() ![]() ![]() |
Right pumped the pedal and it made the most minimal difference, basically none. Which is odd! The pedal does not sink, or go further, it’s just the travel and relative lightness.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
These can be an absolute nightmare to bleed. Some are fine first time, some are just a |
That's a good tip..... |
I will say though that I feel my L405 has a soft travel feel to it compared to my BMW and some other cars ... almost like over assistance, Rather than hitting a travel stop point on the pedal when they bite on the disc, against which you then put more pressure on a a stopped pedal, you keep traveling with the pedal as it increases the bite.
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 177 ![]() ![]() ![]() |
I gave up trying for a firmer pedal after fitting new flexys. I must've bled them umpteen times to no avail. Since then however, I've acquired an iid tool and a pressure bleeder so I'll try again when the weather warms up. A glutton for punishment, that's me. |
My tech has agreed to re do the bleed to see if it makes a difference. It’s not scary and I have confidence in the car/brakes but whilst I can live with the softer feel the travel is just alarming, it’s not the worst but does not seem right as before it was relatively firm,
