![]() | Home > Technical (L322) > 2011 4.4 tdv8 turbo bypass valve and VGT actuator |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1288 ![]() ![]() ![]() |
With regards to P046-77, raise the car to off road height and you will see the actuator rod on the turbo. Get someone to start the engine while you watch the rod, It should flick up and down a couple of times as soon as the engine starts.
StanV8 Member Since: 22 Feb 2025 Location: Northamptonshire Posts: 2 ![]() ![]() ![]() |
Thanks Kevin, I've replaced the actuator, for some weird reason it's arm was in the opposite side to where it supposed to be and was bent as well, so it was no brainer, with bypass valve, I just had it cleaned properly, took apart solenoid, it had oil and other gunk inside, all over diaphragm as well as some oxidation inside the shaft where guide pin moving, put it back in and the code is gone (how lucky was that 😀). Honestly, I didn't pay attention to whether it had a nut on the arm or not, so not sure if I still have the old one. |
