![]() | Home > Technical (L405) > SDV8 crank shaft trigger wheel timing installation manual |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 277 ![]() ![]() ![]() |
Not correct!
heretolearn Member Since: 27 Oct 2024 Location: Kuala Lumpur Posts: 33 ![]() ![]() ![]() |
Appreciate the feedback and thank you for the link 4RRS. I just saw a video by LRTimes ?si=H6-a3Ac3t-O7tlf9. I think at 9mins into the video he was explaining about the freeplay on the tool so he manufactured his own. So there is a fixed dowel pin hole in the crank side which will align with a fixed position to the trigger wheel making it impossible to time the engine wrongly? That's if the shop have the correct tool for it. Is there any requirement to turn the engine to TDC before performing this task? |
Engine does not have to be at TDC as the tool locates relative to the crank and trigger wheel. You literally cannot get it wrong. Make sure the correct tool is used as the 306DT (3.0L diesel) tool will fit but you'll end up with incorrect timing as the tools are virtually identical, but not quite.
You saved me alot of trouble on this one. I would be in a world of pain if gotten the wrong tool for the job. Appreciate the advise. |
Ordered the tool and fitted in a new trigger wheel. Now I'm getting these codes: P0339-2F Crankshaft position sensor "A" circuit intermittent - signal erratic (AB) P0315-32 Crankshaft position system variation not learnt - signal low time < minimum (2B) P0339-65 Crankshaft position sensor "A" circuit intermittent - signal h too few transitions/ events (2B) My first CPS was throwing codes when I replaced the trigger wheel first time which was off by 2 degrees. I changed a new CPS and it worked fine on every occasion other than when I'm revving up to 3.6K rpm at WOT which the car will throw a P0088-17 code. In pursue of fixing this, I've removed the transmission again a month later to redo the trigger wheel with proper tool. Now that the timing is correct the car is throwing CPS codes again although it is still fitted with the new 1 month sensor. I'm thinking if there is a need to relearn the CPS/CKP values now that timing is 2 degrees different (back to factory standards). Are these crankshaft position sensors a 1 time use and will lock to the first adaptation type of hardware? According to GAP such procedure isn't implemented by LR so CPS/CKP learning feature isn't needed. I'm wondering what could be wrong with it. |
I'm not aware the position has to be learnt as its a definitive value with no tolerance. The trigger wheels should only be fitted once due to the possibility of damaging the magnets when removing it. Was it a genuine trigger wheel you fitted, as I have seen on LR time YouTube channel that he had problems with aftermarket items and when he scoped them the magnets were poorly located within the trigger wheel and the car threw correlation faults.
Yes the shop replaced a new and original trigger wheel and fitted it with the correct tool. I'm getting the same symptoms from my factory CPS where the engine cuts off immediately when revved along with CPS codes. The 1 month old sensor also throwing the codes as mentioned on the threads so I have no choice but to get another new CPS next week to see if it makes any difference. I have no access to an oscilloscope to monitor the trigger wheel signal. This is getting pretty frustrating |
I'm at a bit of a loss on this, definitely the correct tool marked with Part No. 303-1237 & V8 on it?
I'm just as puzzled with this one. It's the same scenario as my factory crankshaft sensor unable to run with the 2 degrees off timing new trigger wheel, but the replacement new CPS somehow works. No code, starts up right away, idles and drives fine (most of it). Now that the timing is back to it's intended position, both CPS doesn't work and are throwing codes. I'll be swapping out another new CPS this coming Monday to see if it helps. If not then likely it could the case of a faulty trigger wheel although it's original new. The whole seal refresh exercise has been rather time consuming by now |
Me too!
The replacement CKP sensor is a bosch unit which worked previously. I got into this predicament because I replaced a new main seal so the sensors are dry without any oil contamination. They just stopped working. In a way I'm lucky to address this within a month so supplier is granting me warranty for the sensor. Some quick google searches suggest to relearn the sensors but there isn't such options on diagnostics for LR. Let's hope the new unit miraculously work and that'll be the end of my CKP/CPS drama. |
I'm stumped, I'd go with a JLR CKP and ring and keep my fingers crossed! I don't recall the airgap for the CKP sensor being adjustable, but just check it isn't overly wide.
Swapped a new CKP sensor and all related codes are all gone. But I still have the initial P0088-17 problem I'm trying to solve. Sent my ECU to revert back to factory now to eliminate another possibility before moving on to testing other components,if ECU isn't one of it. |
I assume you've tackled the TSB relating to the fuel pressure switch wiring loom/connector issue? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
