![]() | Home > Maintenance & Mods (L405) > oil overfill |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7979 ![]() ![]() ![]() |
Probably due to 'oil dilution' particularly if it was filled to the top after the last service. Additionally, some garages replace the amount that they drained out, which can be too much......
dave the builder Member Since: 12 Nov 2024 Location: North Wales Posts: 36 ![]() ![]() ![]() |
So do you think it's a problem and I should get them to drop some oil tomorrow then. Any idea on how much to drop or is that a stupid question? Thanks |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8455 ![]() ![]() ![]() |
Better to get some sucked out till it's at the correct level or a bit lower, dropping oil doesn't usually end well...!!!
I didnt know to do that. I've been doing it through the service menu. And mine takes at least 2 maybe 3 hrs after driving to let you check nevermind 10 mins. Nightmare. Thank you. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1635 ![]() ![]() ![]() |
“Churning” is the word.
Thank you , strangely since I put this post up I've gone to check oil and opened bonnet and door went to oil level and straight away let me see it and it said oil level ok. I'm now wondering if it's a sensor. Regarding regens it about every 6 weeks. Thoughts ? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
I have noticed that even the slightest of slopes results in a different reading. Geoff |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
Change the oil its fuel dilution, otherwise the overfilled alarm would have been on in October. 2018 SE SDV8 4.4 Byron Blue |
Ummmm, whoa there everyone, before we all get carried too far away from reality here:
Oil is cheap I would never chance it! It's easy to do yourself.
Yes, I respect and would never argue with that, I change my own oil every 2500 miles/6months, that wasn’t quite the point though:
Mileage at service 70937 23/10/24 Mileage now 73241 So roughly 2400 miles of local driving averaging between 18 and 23mpg from on board display. I know I've had yellow regen notice at least twice possibly 3 times , quickly cleared. Never had an oil overfill warning come on the display ( if they have that on my 2013) only found this issue when I checked as I'm driving 150 miles to holiday on Sunday and same back a week later. I have my oil level this morning cold and it says over filled , yeas last nigh in same spot it was warm and said it was fine . Could it be a sensor ? Do I get the garage to drop the oil even after just 2400 miles, some say urban driving oil needs changing more often ? If it was overfilled in Oct service which garage who I trust say wouldn't have been the case as there's just 2 of them, they said they double check all oil levels I haven't noticed any leaks. I'm so confused as what to do for the best. Last thing I did this trip 3 weeks after that service and it was fine. Thoughts. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1160 ![]() ![]() ![]() |
I agree with Kot just do an Oil change this will give you piece of mind. overfinch modified |
Yes, I agree now too |
