Home > Maintenance & Mods (L322) > Sankey Trailer & Nato Hitch on a FFRR
Page 1 of 3 123>
JustinP
Hi All,
I'm thinking of buying a trailer to carry our camping gear, which should protect the interior from getting scuffed as we attempt to wedge in ever more unnecessary camping bits. Rather than buying an Erde tin box thing, I'm toying with the idea of restoring a ex-military Sankey trailer to tow behind the FFRR.
Is it possible to fit a nato hitch coupling to a the genuine LR multiple height tow bar bracket?
If so, does anyone know if the tow bar height will be suitable for a Sankey?
Cheers
Justin
Post #78555 31st Aug 2011 8:32pm
Vogue
yes it will fit on the tow bar you show. You may need heavy duty washers or a backing plate as the bolts are smaller than the holes on the draw bar. The trailer will tow ok, but it will be nose down on the std RR draw bar.
Your lights will not be plug and play, the sankey is configured for military vehicles, you have two options either the trailer will need to be re-wired to the std uk trailer wiring plug, or use a trailer lighting board.
The sankey is better than any shiite trailer from halfrauds! but they are heavy...
the other good thing is they take std Land Rover wheels, i.e. LR Series, Defender and I have also even seen RR Classic and Discovery alloys fitted.
Post #78562 31st Aug 2011 8:44pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
Incase you haven't seen wiggs's trailer.
http://www.disco3.co.uk/forum/topic47201.html
Post #78572 31st Aug 2011 9:54pm
JustinP
Yep, I've looked at all the photos in Adrians thread Thumbs Up
Post #78574 31st Aug 2011 9:59pm
The problem with the Nato hitch is that it will allow the trailer to rattle about on the hitch. Best convert to a standard hitch if possible for a more comfortable drive.
Post #78577 31st Aug 2011 10:04pm
wiggs
Mine dosent rattle about Shocked
Post #78612 1st Sep 2011 9:02am
Just use plenty of grease but they rattle about as they are designed to be really used under the most extreme conditions we have around the globe Wink
They are worth the outlay if your planning on keeping it for a good few years and the nose down issue is easy enough to resolve Smile
As said mr Wiggs is the man for info on converting if the lighting board option is too Heath Robinson for you Smile
Post #78624 1st Sep 2011 10:45am
ogy
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
If you buy the type shown in your first photo you can turn the tow coupling tube upside down and bolt it underneath the trailer A frame instead of on top. It will then ride level with your standard height tow bar.Theres a bit of work modifying the brake linkage but ive seen it done before.
Post #78752 1st Sep 2011 7:24pm
isnt this trailer going to slow you down a bit justin....
dont know what it is but there is a speed limit for cars towing trailers, maybe someone will inform us here..
Post #78788 2nd Sep 2011 7:48am
johnson1
60mph.
Post #78789 2nd Sep 2011 7:50am
is it also only the first two lanes on the motorway..
Post #78790 2nd Sep 2011 7:52am
dan_uk_1984
Towing regs should be waived for FFRR's. Towing a small 6x4 trailer at 60mph - WTF is that about.
Post #78800 2nd Sep 2011 8:26am
That is the speed limit on the kings highway, off piste its what ever you want Very Happy
Post #78811 2nd Sep 2011 9:27am
tbh when you see these trailers being pulled at 70/75 mph and they start bouncing side to side ,then that's probably why there's a speed limit for them...
Post #78813 2nd Sep 2011 9:35am
JustinP
On the drive to the south if France, we saw many trailers being towed at 80mpg, and they all looked stable.
However I'm not sure how a heavy Sankey would cope at that speed.
Post #78817 2nd Sep 2011 10:02am
Page 1 of 3 123>
