Home > General (L405) > Querys about buying a used L405
Chalky
jcoops wrote:
Chalky wrote:
Hi
I've had many FFRR and Disco's all with various versions of the 3.0 engine and haven't had any issues with any of them engine-wise. The Euro engines are very smooth, quick and economical (true 30mpg over all journeys, including under 10 miles)
I've always had SE versions with a spec good enough for me, most of which I don't use anyway! HUD is definitely worth having though. When the L405 first came out most reviews said the 3.0 SE was the "sweet spot" of the range. My 21.5MY is so good I wouldn't change for a L406 as I don't think it's worth the money at £125k for the same spec car.
What do you mean by HUD?
HUD means Head Up Display
Also not a single issue with any engine. I also have friends who have the same engines in Disco's and FFRR's and none of them have had any problems at all. Thumbs Up All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #712216 19th Feb 2025 1:29pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Not got any stats to say it is more or less than 5%.
I know a good independent and asked him how many 3.0 he sees with the crank bearing problem. His answer was "not that many".
I do know 2 people, both with Discos, that had the issue. One did admit that the car had been chipped and that might have had an effect, and the other didn't seem to have any reason (seemingly well maintained and only done 50k, though he was the 2nd owner). Equally, I also know loads of others with the 3.0 engine that have never had any problem. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #712231 19th Feb 2025 3:05pm
cass
My concern with the 3.0 is that the crank can fail at any time without warning for no apparent reason. Even if only a tiny % fail then IF you’re unlucky the cost of repair will render a 10 year old car scrap unless you’re handy with the spanner’s.
On the plus side I would guess that most of those that are going to fail probably have by now?
Post #712237 19th Feb 2025 5:02pm
