Home > Technical (L405) > Headlight issue
Maktraher
United States
Headlight issue
So my 2018 facelift L405 left hand headlight stopped working a few weeks ago. My garage (not official RR) told me it needed a new headlight. Managed to get one from Charles Trent second hand (brand new over 4k!). New headlight installed, but car will not start. Engine turns and occasionally catches but then dies. Garage has no idea. HELP! ...
Post #711625 12th Feb 2025 7:57am
disconnect the newly installed replacement headlight and see if it starts...if it does then its the headlight thats causing the problem..
if it doesnt start then you've caused this problem with the install... ... - .- -.
Post #711628 12th Feb 2025 9:01am
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I don't know which garage for now doesn't have diagnostic tool, even basic one to read pcm only. It will let you know where to start from. As Stan said plug it off to see if it causing some can bus issues then dig it further. But garage has to know basics like this even not RR specialist.
Post #711731 13th Feb 2025 1:26pm
