![]() | Home > Technical (L405) > Headlight issue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
disconnect the newly installed replacement headlight and see if it starts...if it does then its the headlight thats causing the problem..
sgorianin@gmail.com Member Since: 11 May 2021 Location: London Posts: 34 ![]() ![]() ![]() |
I don't know which garage for now doesn't have diagnostic tool, even basic one to read pcm only. It will let you know where to start from. As Stan said plug it off to see if it causing some can bus issues then dig it further. But garage has to know basics like this even not RR specialist. |
