![]() | Home > Maintenance & Mods (L322) > Gearbox fault: P0783-64 (ED) 3-4 shift - problem solved |
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 108 ![]() ![]() ![]() |
Quite surprised not to have prompted a response as yet…is this a rare fault? Des
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3195 ![]() ![]() |
RRphil is the gearbox specialist on here. His word is legend.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 ![]() ![]() ![]() |
If it only started after a transmission service, is it definitely the correct oil that was put in it and has the level has been set properly?
Thank you both. Fingers crossed RR Phil sees my post and is prompted to comment.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 ![]() ![]() |
Of all the gearshifts, the 3-4 upshift is certainly the most common issue with the 6HP26X in the L322 (followed by the 2-1 roll-out shift). Part of the reason, I suspect, is due to the fact that the torque converter lock-up clutch is timed to engage its ‘controlled slip’ mode just before the 3-4 shift, which can make it difficult to differentiate between the two events i.e. LUC activation and the gearshift. The lock-up clutch is engaged in a very lazy way over a period of 2 seconds or so.
Wow thank you so much @rrPhil. I really appreciate it.
You were right @RRPhil. It’s very hard to catch the fault occurring!
That could be indicative of a worn rear stator bush, allowing the E-clutch hydraulic circuit to leak & lose pressure. The E-clutch is used in 4th, 5th & 6th gears and the control system inhibits shifting into any of these higher gears to protect the clutch from excessive slip. 1st, 2nd & 3rd gears, meanwhile, work fine.
Phil |
It could be that but when the bong occurs I lose 1st and 2nd gears too. Would that still point to it being this issue?
The bong probably indicates the transmission going into failsafe, which will lock the transmission in 3rd gear until the ignition is cycled. There’s nothing that’s conclusive with your symptoms but, if the stator bush is leaking, then this will be highly temperature dependent i.e. leakage increases as the oil viscosity reduces with temperature.
Thanks again @RRPhil. Looks like there’s some testing to do!
As a reminder, this relates to a problem I was experiencing with my 6HP26 gearbox.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 930 ![]() ![]() |
Thanks for posting your fix. Well done glad it's all sorted. |
