Home > Technical (L405) > Service Schedule 120K +
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
This may have been covered in the past, but the search function doesn't seem to be working at present so :
My 2014 4.4 SDV8 had its 120K service schedule last year, and an interim oil change before Christmas (have an oil change either side of the main service) which means the oil seems to be changed every 4-5Kmiles (4 months) , so what do we do when we've run out of service schedules, go back to the beginning and start with the 16K? or is there a schedule for older vehicles where the likes of tensioners/ bushes and the like are replaced.
Anyone know?
Post #711102 5th Feb 2025 12:31pm
I always presumed we went back to the start and treat it as zero miles.
The tensioners and bushes aren’t service items as such, but more of a change when they’re broke. Definitely worth looking at the belt tensioner if it hasn’t been done. Mine was starting to wear and run off centre on my 16my with 65k. Genuine tensioner is getting on for £200 now, which is daft as they were about £130 last Time I did one on my 322 4.4……
My big service is due next year. Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #711104 5th Feb 2025 12:49pm
go to your online service history and select the service menu... ... - .- -.
Post #711109 5th Feb 2025 1:30pm
goldeneye32
So when you log onto the online service schedule the options only appear to go up to 160K some nice prices there too (Salisbury JLR) particularly like the 160K mile service, if it doesn't show clearly its £2814.97..............bargain!
There is a box that says 'I don't know which service I want' which deciphered means charge me what the hell you like for doing naff all, or am I just a sceptic............which is why I use Independents, but sadly they are not sure of what to check/service at 176K
Maybe just need to apply some common sense and service as per 16K and advise checking a bit more rigorously.
Post #711111 5th Feb 2025 1:49pm
you're correct , it does only go up to 160k
have you got any info from a dealer? ... - .- -.
Post #711112 5th Feb 2025 1:56pm
goldeneye32
No, haven't contacted one yet, might give one a shout and see what they say.
Post #711113 5th Feb 2025 2:01pm
