![]() | Home > Technical (L405) > P0088-17 high fuel rail pressure on WOT/ high rpm |
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 108 ![]() ![]() ![]() |
I would think it would be
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1799 ![]() ![]() |
Why discount the harness? It's a well known, well documented issue |
heretolearn Member Since: 27 Oct 2024 Location: Kuala Lumpur Posts: 33 ![]() ![]() ![]() |
I didn't consider the harness is because on data logging the commanded fuel pressure vs actual fuel pressure are both at very similar trajectory. The warning only triggers when I'm WOT at 4k rpm, which may indicate additional pressure build up. Went through iid tool user manual again today and noticed it is recommended to reset fuel lift pump after a remap. So far it hasn't triggered any fault code on 1st and 2nd gear pulls. I'll try higher speeds in the next few days |
Reset fuel pump lift hasn't yield any favourable results so I'm back to square one. Iid tool couldn't clear adaptations so next is to order a fuel pressure sensor to see if this solves my problem. |
Attached a log here incase anyone can share their thoughts. Exact point of trigger is at 3.6k rpm at full boost, WOT. |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 214 ![]() ![]() |
How did you reset it please? 2012 Vogue TDV8 in Aintree green over sand |
Thank you |
