Home > Technical (L405) > P0088-17 high fuel rail pressure on WOT/ high rpm
heretolearn
Malaysia 2019 Range Rover Vogue SE SDV8 Loire Blue
Hi guys. My sdv8 tends to throw P0088 code which ends up with limited performance everytime i hit full throttle to overtake. I've searched through many other threads in regards of this subject and only found other members having P0088 on start up. Well mine isn't the case here. It drives well on most occasions but when I floor it to overtake it will throw high fuel rail pressure code. I doubt it's the wiring harness giving bad signals. It feels like I'm getting some blockages in the system instead. Can members here advise me how does the fuel system work in the L405 SDV8?
Does it go to the rails first > fuel filter > fuel cooler >back into the tank?
Trying to figure if I have a congested fuel filter. Couple weeks ago I had the entire engine and transmission out to change all seals, mounts, bearing and hoses. 1 of service item was the fuel filter. However I've only found that the OEM filter measures 2mm shorter than the original after an initial start up (hence leaking) and I had no choice but to reuse the old filter temporarily as shops are closing for a week holiday here. Before I started this process the car ran fine. I'm unsure if the old filter somehow developed a clog after it was exposed to air for 2 weeks when I was putting everything together.
Appreciate some pointers.. Thanks
Post #710744 1st Feb 2025 8:22am
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
I would think it would be
From tank to filter
From filter to cooler
Cooler to high pressure pump
High pressure pump to rails
Have a look on here, might make it clearer
https://landrover.scuderiacarparts.com/par...4406/80843
https://landrover.scuderiacarparts.com/par...4406/80844
https://landrover.scuderiacarparts.com/par...4406/80842 2017 (67) Vogue SE Corinthian Grey
Post #710747 1st Feb 2025 10:41am
Mikey
Why discount the harness? It's a well known, well documented issue
Post #710765 1st Feb 2025 3:22pm
heretolearn
I didn't consider the harness is because on data logging the commanded fuel pressure vs actual fuel pressure are both at very similar trajectory. The warning only triggers when I'm WOT at 4k rpm, which may indicate additional pressure build up. Went through iid tool user manual again today and noticed it is recommended to reset fuel lift pump after a remap. So far it hasn't triggered any fault code on 1st and 2nd gear pulls. I'll try higher speeds in the next few days
Post #711015 4th Feb 2025 12:10pm
heretolearn
Reset fuel pump lift hasn't yield any favourable results so I'm back to square one. Iid tool couldn't clear adaptations so next is to order a fuel pressure sensor to see if this solves my problem.
Post #711949 16th Feb 2025 6:09am
heretolearn
Attached a log here incase anyone can share their thoughts. Exact point of trigger is at 3.6k rpm at full boost, WOT.
Post #711950 16th Feb 2025 6:12am
heretolearn
Post #711951 16th Feb 2025 6:13am
toby1
heretolearn wrote:
Reset fuel pump lift hasn't yield any favourable results so I'm back to square one. .
How did you reset it please? 2012 Vogue TDV8 in Aintree green over sand
Post #711956 16th Feb 2025 8:23am
heretolearn
I reset it using IID tool under service/test > PCM > Fuel Lift Pump Reset
Post #711972 16th Feb 2025 12:29pm
toby1
Thank you Thumbs Up 2012 Vogue TDV8 in Aintree green over sand
Post #711976 16th Feb 2025 1:52pm
