![]() | Home > Technical (L405) > Lean when cornering amber light |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1440 ![]() ![]() |
The active dynamics system works to control lean on cornering using hydraulics ... the car knows how much it should lean, and if its beyond that, it'll throw errors.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi this is fault code C1057-14 (2C) Rear axle - Pressure regulating valve - General electrical failure - circuit short to ground or open Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Ok.
Hi ok great cheers for this is this the only only valve block as I though there was one at the rear of car also? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Hi just to clarify then it’s the front valve block & not the rear as it states rear valve block on the fault code of IID TOOL.
