![]() | Home > Technical (L322) > Strange climate control issue |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 38 ![]() ![]() ![]() |
This happened to me on a particularly hot day max 38oC driving through the Karoo about 8 hours into my journey home with about 2 hours more to go. All the fans blowing, no air coming out! Very uncomfortable!
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 58 ![]() ![]() ![]() |
Sorry should have said that it’s been regassed a couple of time in the time I have had the issue and confirmed the correct volume of refrigerant used. |
When I did the re-gas they had a very sophisticated machine which was able to measure the amount of refrigerant and dye inserted with a bunch of other metrics. It then also provides a report. If you can get the same done back to back you may be able to determine if there is a leak. And if they included dye in the refrigerant they can trace the leak. Good luck. 2011 Vogue SE 4.4 TDV8 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2558 ![]() ![]() ![]() |
Is there any difference when on recirc? Presumably the cabin air filter has been checked. |
Recirc doesn’t make any difference when the issue is evident. When running OK then record does the usual and helps speed up the cool down or warm up and eventually steams the car up! lol
@deejay - where I had the air con gassed last gave me a report of exactly how much they vacuumed out and again how much they reinserted and both figures were exact to factory specs. The time before when I had it done I asked for a UV due to be added as well and we have never had evidence of any escape. So I’m pretty confident it isn’t a refrigerant leak. |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Similar issue with mine. Blower blowing, but all vent doors are closed.
