![]() | Home > Technical (L322) > Front and rear passenger doors not unlocking. |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Needs a change in the CCF regards central locking dont think it can be done on the screen certainly couldnt on my 08 had to edit CCF with my Gap iid . |
Jimmy86 Member Since: 27 Feb 2024 Location: East midlands Posts: 21 ![]() ![]() |
Thanks. As it happens my iid tool arrived yesterday. Just trying to work out how it all works. Is straight forward enough to change the CCF? |
When you bind the tool to the car it will copy ccf as it is then you can edit ccf as you need basically, I had the battery on charge for couple hours before and (rightly on wrongly) left it connected while editing ccf as it can soon run battery down. My car had drive away locking when I got it and don't like it if I feel in need to lock the car when stood in traffic I just push the button on the dash I also enabled wipers to intermittent when stopped at lights. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Pretty sure what you describe is how it’s meant to operate unless you change CCF as covered above. To open or lock all with the fob you have to press it twice quickly. One press does drivers door only as this was done if you are alone in a dodgy area and you don’t want someone you don’t know jumping in the passenger side when all the doors unlock, you get the idea….
