Home > Technical (L322) > Front and rear passenger doors not unlocking.
Jimmy86
Afternoon all.
Having a strange issue with my 2010 3.6TDV8.
I am able to unlock and open all the doors using the fob and then can load up the car and drive away. When I park up, you can feel the drivers door unlocking when I open from it from the inside, all other doors remain locked and cannot be opened from the outside unless I unlock them again using the fob. Is there a way to set up the car so that all doors open from the outside once the car has been parked up and the drivers door opened? It mainly an issue when I have the kids in the back of the car, means I have to find the fob again and unlock the doors so I can get them out.
Probably missing something obvious but any advice would be appreciated.
Cheers
Post #710054 24th Jan 2025 3:13pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Needs a change in the CCF regards central locking dont think it can be done on the screen certainly couldnt on my 08 had to edit CCF with my Gap iid .
Post #710104 25th Jan 2025 1:10am
Jimmy86
Thanks. As it happens my iid tool arrived yesterday. Just trying to work out how it all works. Is straight forward enough to change the CCF?
Post #710113 25th Jan 2025 8:56am
kds2
When you bind the tool to the car it will copy ccf as it is then you can edit ccf as you need basically, I had the battery on charge for couple hours before and (rightly on wrongly) left it connected while editing ccf as it can soon run battery down. My car had drive away locking when I got it and don't like it if I feel in need to lock the car when stood in traffic I just push the button on the dash I also enabled wipers to intermittent when stopped at lights.
Post #710134 25th Jan 2025 1:02pm
mjdronfield
Pretty sure what you describe is how it’s meant to operate unless you change CCF as covered above. To open or lock all with the fob you have to press it twice quickly. One press does drivers door only as this was done if you are alone in a dodgy area and you don’t want someone you don’t know jumping in the passenger side when all the doors unlock, you get the idea….
When I park up I just press the unlock button on the dash and they all open.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #710137 25th Jan 2025 1:36pm
