![]() | Home > In Car Electronics (L405) > Android infotainment screen - No Signal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
need more info than that..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8549 ![]() ![]() ![]() |
If that's the reversing camera display then chances are your camera has failed.... Pete
Fergy Member Since: 17 Feb 2024 Location: Berkshire Posts: 5 ![]() ![]() |
Thanks for your reply. It’s Android Version 12 Build number QP1A.190711.020 Not sure if the info above helps at all? Thank |
When I put it into reverse the reversing camera still works. Just can’t choose audio input etc on car ui. Thanks |
Just to clear things up a bit.
paul1454 Member Since: 19 Feb 2025 Location: Tennessee Posts: 1 ![]() ![]() ![]() |
Did you ever get this figured out? having the same issue |
