Home > In Car Electronics (L405) > Android infotainment screen - No Signal
Fergy
Just had the error message appear in the picture below.
Any help greatly appreciated.
Thank you
Post #710016 23rd Jan 2025 10:29pm
need more info than that..
what make , model ,size, who fitted it...have contacted the manufacture or seller? ... - .- -.
Post #710017 23rd Jan 2025 10:33pm
If that's the reversing camera display then chances are your camera has failed.... Pete
Post #710020 23rd Jan 2025 10:42pm
Fergy
Thanks for your reply.
It’s Android Version 12
Build number QP1A.190711.020
Not sure if the info above helps at all?
Thank
Post #710022 23rd Jan 2025 11:11pm
Fergy
When I put it into reverse the reversing camera still works. Just can’t choose audio input etc on car ui.
Thanks
Post #710023 23rd Jan 2025 11:13pm
Fergy
Re: Android infotainment screen - No Signal
Just to clear things up a bit.
The android infotainment screen works. It’s once I select Car UI that I get the no signal message on the screen.
Post #710026 24th Jan 2025 12:19am
paul1454
United States 2014 Range Rover Autobiography 5.0 SC V8 Santorini Black
Did you ever get this figured out? having the same issue
Post #712260 19th Feb 2025 9:28pm
