Home > Maintenance & Mods (L322) > Auxiliary heater location 2012 L322 tdv8 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3176 |
It should be on the pax side rear of the engine bay. access normally involves removing the inner wheel arch cover IIRC.
17th Jan 2025 12:11pm |
Bazzer58 Member Since: 18 Oct 2024 Location: Cornwall Posts: 3 |
Thanks. I will try and find it.
17th Jan 2025 1:14pm |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 110 |
That's where mine was. Relatively easy to get to though getting the liner off is a bit of a pain. Pretty obvious once you get access, its at the rear of the wheel well, is a relatively small bx with a long exhaust hose out of it pointing down. |
17th Jan 2025 2:58pm |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 26 |
Sorry wrong section 2012 Westminster 4.4 tdv8 |
17th Jan 2025 3:40pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
This is a pic from the Wiki about brake line replacement on a TD6…. Gives you an idea of location though….
17th Jan 2025 5:46pm |
