Home > Technical (L405) > Battery related data and scan tools
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
As I have a battery issue in the current cold weather, I'm interested in keeping an eye on data through the scan tool. With my Autel AP200 I can see live values from the Gateway module. However, as with many values, some of them seem like they might be either unused, or nonsensical.
I have the following values showing, and I wonder if anyone else would like to compare with their values, or just comment. There are references to "Battery" and "Battery 2". I assume that "Battery" Is the primary battery, under the boot floor, and that "Battery 2" is the auxiliary battery behind the panel on the right-hand side of the boot.
Values:
Number of vehicle battery replacement resets: 0 (I assume this value is unused as I can't believe that there have been no resets on a 11 year old car)
Vehicle battery - time in service: 368 s (Clearly the unit is not seconds. But what unit, if anything, is it?)
Vehicle battery state of charge - estimated: 59.00%
Vehicle battery - time in service - Battery 2: 1428 s (Clearly the unit is not seconds. But what unit, if anything, is it?)
Vehicle battery state of charge - estimated - Battery 2: 0.00% (Is this value unused, or is it genuinely saying that the battery is completely flat?)
I will get that auxiliary battery checked, but I have to remove the luggage divider and unbolt its bracket to get at the battery.
Thanks
Post #708822 10th Jan 2025 9:32pm
Gremlin500
Scan tool is a waste of time.
Get a proper battery tester, and test the batteries, but not connected to the vehicle. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708830 10th Jan 2025 11:49pm
caymanblack
All that messing about , I would just replace both. Its amazing how everything works better when new batterys are fitted to these cars. overfinch modified
Post #708859 11th Jan 2025 2:32pm
Gremlin500
Very true, FFRR’s eat batteries for breakfast, yum, yum! Razz Laughing
You don’t actually have to remove to test, only disconnect one terminal, but yes it’s a bit of a faff with this cold weather!
If you buy from Halfrauds don’t they fit for free?
I got one of those Kingbolen BM580’s from AE, they are actually pretty decent quality, and now half the price, only about a tenner. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708861 11th Jan 2025 3:04pm
Just did both my batteries, ordered Exide EK960 and EK720 from Tanya for about £250 for both delivered. Not worth faffing about if you are having trouble. There is nothing that can't be fixed with a hammer😜😜
Post #708896 11th Jan 2025 9:32pm
Gremlin500
Exactly.
For a FFRR, batteries are a consumable, in fact more like screenwash than brake pads or oil Rolling with laughter
Must check to see if mine are AA or AAA, can’t have long left Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708901 11th Jan 2025 10:21pm
hmallett
Re: Battery related data and scan tools
Having had a few days to see the changes, I can tell you that the "time in service" values are in days (though the scan tool says seconds).
The "state of charge" values can be seen to change for battery 1 as I charge the battery via the terminals under the bonnet. The battery 2 value doesn't change for me, but I'm not surprised, as the battery is 12 years old. New one is in the post. The main battery was changed a year ago, so that will remain, for now.
Post #708983 12th Jan 2025 10:07pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Rolling with laughter Rolling with laughter Rolling with laughter
*changes battery with new tank of fuel* Formerly happymadison1978
Post #708984 12th Jan 2025 10:08pm
Gremlin500
Very Happy
Of course we joke about changing a £200 battery like a fresh pair of boxers, but (straying possibly a little OT), surely this is a pittance, compared with full-on EV’s where it might cost a 5-figure sum every ten years or so? Shocked
I for one will never go full EV until manufacturers are forced to display the replacement cost of a new HV battery pack on the sales card, this needs to be mandatory, or EV sales will never grow in the way expected, due to deep public mistrust of both mfrs & govt.
Sorry to go OT. Embarassed “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708986 12th Jan 2025 10:58pm
hmallett
Following up on my own post, now I have changed the auxiliary battery and reset the BMS statistics for it:
hmallett wrote:
Values:
Number of vehicle battery replacement resets: 0 (The value is still at 0, so I assume that it is not used)
Vehicle battery - time in service: 368 s (This value is in days)
Vehicle battery state of charge - estimated: 59.00% (This value changes, quickly)
Vehicle battery - time in service - Battery 2: 1428 s (This value is also in days. Mine reset to 0 after the reset)
Vehicle battery state of charge - estimated - Battery 2: 0.00% (This value is used, and changed to 90% for me when I installed the new battery and reset the BMS)
Post #709375 16th Jan 2025 6:55pm
