Home > Maintenance & Mods (L405) > P400e High voltage heater |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 |
I thought I’d share my experience with the P400e HV heater. I bought a Sport about 18 months ago and ended up rejecting it as the HV heater had failed and they were on 6 months back order. It’s a £1500 repair at JLR and £600 of that is labour as they quote a few hours (it took me 20 mins last time!).
7th Dec 2024 2:05pm |
Chip41 Member Since: 08 May 2023 Location: Manchester Posts: 6 |
Heroic - great write up and just what I need to do.
8th Dec 2024 5:28pm |
There are three bleed screws (two to the left side of the engine and one above the FBH back left. Just open them when running to let the air out.
12th Dec 2024 8:51pm |
Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61 |
Thank you for this report as I've just stumbled upon exactly the same issue. My P400e does not start in EV/Hybrid mode and with the temperature went down it runs 90% on ICE. It starts in EV (Hybrid, with no EV button active) with climate off, so apparently my HVH is down, waiting for the code reader delivery to confirm.
29th Dec 2024 8:04am |
Hi, the part number for the newer version of your heater is in the original post. If you google that number you’ll find a few on line. It’s a main dealer part, but I bought mine from a LR parts specialist called landranger. New genuine LR part has 2 year warranty. I think my original item was 50 plus, but the new part is 70. I can’t picture as it’s installed. My Previous RR's!
1st Jan 2025 7:04pm |
