Home > Maintenance & Mods (L405) > Locking wheel nut key obsolete |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8597 |
Think there was a set of nuts and a code A key in the for sale section……
30th Dec 2024 3:32pm |
Pablo398 Member Since: 31 Dec 2023 Location: Wales Posts: 16 |
Thanks I’ve sent a PM let’s hope he’s still got them. 👍 |
30th Dec 2024 3:42pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Dumb question, but are you sure it's lost ?
30th Dec 2024 4:05pm |
It’s a good point the proper place is hard to spot as it has a cover over it….. There is nothing that can't be fixed with a hammer😜😜
30th Dec 2024 4:07pm |
Yes definitely lost took me an age to find the first time so will never forget its place. Thanks anyway. |
30th Dec 2024 4:12pm |
Glackowitz Member Since: 06 Sep 2020 Location: Oregon Posts: 8 |
I just removed my locking lugnuts, bought the car and found it had no key. Used a 21mm 12point socket, just slightly fits over lugnut, tapped it on about 3/8 of an inch to make sure it doesn’t slip then used a breaker bar to take it off. Left it a little bit on the stud to work the socket off the lug then finished removing the nut by hand, put oem regular nuts back on. |
31st Dec 2024 7:15am |
