Home > Technical (L322) > Front left height sensor loom |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
The wires from the suspension sensor to connector pair C2411/12 are 2.7m long which at a guess puts the connectors behind the LF footwelll side cover. The wires from the connector pair to the suspension ecu are 6.8m long.
3rd Mar 2023 4:15am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 400 |
hmm i can check that harness tbf but the issues started when i replaced the 2 front left/right struts.
3rd Mar 2023 8:28am |
Is it a suspenion fault or an adaptive dynamics fault or both?
3rd Mar 2023 9:47am |
It's both, car does have adaptive suspension. I'll be stripping down my repair and checking tomorrow.
3rd Mar 2023 9:51am |
The ebay one might only be a single sensor for height control on earlier non-CVD vehicles rather than a double one that's required for CVDs. |
3rd Mar 2023 7:39pm |
i checked tbf, had all the pins and it tbf does claim to be CVD one. i think to eliminate that issue ama just order a LR Its actually a sport
fixed.
23rd Mar 2023 1:03pm |
joejoe300 Member Since: 22 Dec 2024 Location: Nottinghamshire Posts: 9 |
Hi did you get to the bottom of your issue |
22nd Dec 2024 11:42am |
take a picture of your sensor, theres a specific way they are installed.
22nd Dec 2024 12:05pm |
Its mounted with the arm facing out |
22nd Dec 2024 12:09pm |
