Home > Maintenance & Mods (L405) > 2016 Td6 - Single Turbo O2 Sensor location P2551-13[solved]
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Brain Trust,
I am getting code P2251-13 - Oxygen sensor negative current control - circuit open. Bank 1 - Sensor 1.
I know it is generally on the right side of the engine(with cyl 1), but the workshop manual does not show the location for a single turbo variant...
Any help - always appreciated!
JDW 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #707217 18th Dec 2024 10:21pm
JDGeorgia
Found a diagram of where the O2 Sensor it.
Even though it says Bank 1 Sensor 1 - which would normally be on the same side as Cylinder 1...
There is only 1 set of O2 Sensors on the TD6 and it is behind the left side of the engine.
So no idea on how to access this.... But the adventure continues 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #707299 20th Dec 2024 3:46pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Thanks for the update. At least you're on the right track.
Post #707310 20th Dec 2024 6:00pm
Spridget
Just looking again at your diagram JD. I think it's a twin turbo engine, it has 2 air boxes and apparently that's the give away. Maybe that makes a difference? 🤔
Post #707318 20th Dec 2024 8:59pm
JDGeorgia
Yes - I see that now... I have the single turbo variant - but I still think that there are no O2 Sensors on the right side (Passenger in most of the world)
I will keep looking though!
Good catch my friend! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #707335 21st Dec 2024 4:08am
