Home > Technical (L460) > L460 Heater Gremlin
chris595959
2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
L460 Heater Gremlin
The heater on my 2023 4.4 Autobiography is playing tricks on me.
Around town set on Auto at 22C and all is well .
Venture onto the motorway and slowly the cabin temp falls and have to increase to 25C to maintain heating .
Also the dash vents start to bleed very cold air. Tried shutting them down but you can still feel very cold air escaping.
Any thoughts on this
Post #706962 15th Dec 2024 5:22pm
martincfreeman
Location: Flatlands of Lincolnshire (but the Kerbs are pretty high!)
United Kingdom 2018 Range Rover Vogue SE TDV6 Silicon Silver
Oddly, mine does something similar (AB D350). Also the fans semi to be on high all the time. In the L405, there was a setting for Auto that set quiet / gentle fan etc.
Anybody else having anything similar?
Post #707836 29th Dec 2024 8:28pm
AndyS
I find I have to turn the heat level to 22/23 to get a comfortable cabin temperature and also find the temp can vary when on auto.
Mines also got a noisy fan which is being looked at this week along with the coolant heater replacement. Current fleet:
2020 McLaren 600LT Spider
2020 Mercedes C300 Cabriolet
2023 L460 PHEV 440 SE
1992 Lotus Esprit turbo
2019 Alpine A110 (French rubbish now gone)
Post #707901 30th Dec 2024 11:59pm
Clipper
Have you tried moving it to the automatic speed setting?
Post #708159 3rd Jan 2025 9:50am
EdJ
I have had a few issues with mine on a recent long journey to the Alps. The windows started misting up and when I clicked on the max demist option, nothing happened. Also if I tried Max A/C, nothing happened.
It seems fine again now but I will mention to the dealer. 2024 Range Rover P550e AB
Post #708186 3rd Jan 2025 1:16pm
martincfreeman
I found something out yesterday, the fan has an Auto setting but that seems different to the Auto heat control.
The fan Auto allows you to set the max speed of the fan (it doesn’t make sense to me) so I gave now set it to Auto with a speed of 3. It seems much better. The fans are quiet but still auto (I think).
I did it on the rotary controls (pulled, set to auto, push and then pull, turn to 3.. the auto stays on) but I think it can also be done on the panel.
Heating seems much more akin to the L405 now which was gentle.
Post #708199 3rd Jan 2025 6:21pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
On a trip back from the Arlberg we had exactly this, screen wash for down to -10 and jets not defrosting and even on max windows misting up, just what you want from a hundred plus grand car.
Perhaps LR she ditch the bling and concentrate on the basics. letters not necessarily in the right order
Post #708201 3rd Jan 2025 6:39pm
