Home > Technical (L322) > Alarm LED?
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Alarm LED?
Should my 2012 model TDV8 have an LED to tell when the alarm is on?
I have in the middle of the top of dash, a red plastic dome thing that never lights.
Is this the alarm LED to show it is set or something else please?
Many Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #706908 15th Dec 2024 10:26am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi, the alarm led on mine is on the right side of the main instrument display and is not obvious when standing outside the car from the drivers side. If you sit in the car and lock it you should see if it’s there on yours.
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #706909 15th Dec 2024 10:37am
PeteT80
As Rich said the alarm LED is to the right on the instrument display. The red plastic dome thing is a sunlight sensor and adjusts the air con accordingly.
Post #706913 15th Dec 2024 11:08am
Buellie
Thanks Fellas, I have the flashing light on the instrument cluster, having sat in the car locked.
Seems a strange place as I would prefer if it was more visible to by-passers and wrong'uns. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #706950 15th Dec 2024 3:06pm
