![]() | Home > Technical (L322) > Alarm LED? |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Hi, the alarm led on mine is on the right side of the main instrument display and is not obvious when standing outside the car from the drivers side. If you sit in the car and lock it you should see if it’s there on yours.
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 222 ![]() ![]() ![]() |
As Rich said the alarm LED is to the right on the instrument display. The red plastic dome thing is a sunlight sensor and adjusts the air con accordingly. |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 152 ![]() ![]() ![]() |
Thanks Fellas, I have the flashing light on the instrument cluster, having sat in the car locked.
