![]() | Home > Technical (L405) > Fuse for front heated screen. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7992 ![]() ![]() ![]() |
By half, do you mean one side ?
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 238 ![]() ![]() ![]() |
Well I was told. By a windscreen fitter, who cam to fix a chip, that it was a replacement, because it had Pilkington and not Range Rover stamped on it.
I'd guess that the drivers side wasn't plugged in.
This thread might also help https://www.fullfatrr.com/forum/topic54132...p;start=15 |
Thank you so much Alistair. You probably won't believe this. I've seen that video, checked my vehicle. The only thing under that drivers side panel is the brake servo and fluid reservoir. Odd ? 2013 SDV8 4.4 SE Luxor.
