Home > Technical (L405) > Fuse for front heated screen.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Half of my heated screen doesn't appear to work. Been trying to find the fuses. It's not in the glove box one. Just can't find the under bonnet ones at all. I've read to upgrade from 30 to 4o amp. Any idea where the fuse is please. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #706777 13th Dec 2024 2:12pm
By half, do you mean one side ?
AFAIK, there are connectors on either side, so maybe one not connected properly ?
Has the windscreen been replaced ?
Post #706785 13th Dec 2024 5:41pm
GrandadRob
Well I was told. By a windscreen fitter, who cam to fix a chip, that it was a replacement, because it had Pilkington and not Range Rover stamped on it.
The passenger side works but not the drivers side. 2013 SDV8 4.4 SE Luxor.
Post #706792 13th Dec 2024 6:23pm
I'd guess that the drivers side wasn't plugged in.
You can remove the side covers, there's a bolt under the tab with Airbag (or similar) stamped on it. You should be able to see the tab on the windscreen and a cable somewhere.
On the L322 there were 2 connection points, one for the windscreen and one for the wipers only - not sure whether the L405 is the same.
Post #706797 13th Dec 2024 7:21pm
This thread might also help https://www.fullfatrr.com/forum/topic54132...p;start=15
Post #706798 13th Dec 2024 7:24pm
GrandadRob
Thank you so much Alistair. You probably won't believe this. I've seen that video, checked my vehicle. The only thing under that drivers side panel is the brake servo and fluid reservoir. Odd ? 2013 SDV8 4.4 SE Luxor.
Post #706876 14th Dec 2024 7:06pm
