Home > Maintenance & Mods (L405) > Emergency Neutral lever
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Preparing for the day that I need it, I'm looking for the neutral lever on my 2015 L405 TDV6. I believe that it's under the cup holders but how does the liner come out without damaging something? I can see a little slot at the rear edge. Any suggestions?
Post #706397 8th Dec 2024 2:58pm
I think you need a screwdriver to lever the tab at the bottom of the cup holder - on the right of your picture
Workshop manual just says -
To disengage the park lock:
Slide open the drinks compartment lid in the floor console.
Remove the trim from the base of the drinks compartment.
Rotate the locking cylinder of the emergency park release lever 90
degrees counterclockwise.
Apply the footbrake, pull the operating lever upwards and ensure it locks
in the vertical position.
Raising the operating lever causes the emergency park release cable to
rotate the park interlock lever on the transmission, which disengages the
parking pawl and engages neutral. This allows the vehicle to freewheel.
Post #706401 8th Dec 2024 3:19pm
Kot
https://www.ownerinfo.landrover.com/docume...3/G1807549 2018 SE SDV8 4.4 Byron Blue
Post #706405 8th Dec 2024 4:50pm
Spridget
The compartment base submitted to poking and prodding with a flat blade screwdriver to reveal the Neutral selector mechanism in all it's glory.
All I need now is a recovery to try it out. Big Cry (Don't tempt fate}
Thanks for the info
Pete
Post #706479 9th Dec 2024 3:41pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
It is actually a great thing to do sitting in the driveway.
My Son's 2016 L494 needed this and we found out in the middle of the night that the cable had popped out of the red 'lever' (I don't think it was ever inserted properly). Then once we got that sorted - we found out that the little clip that holds it 'unlocked' was messed up so we had to wedge a pair of needle nose in the dup holder to keep it open...
Bravo to you for checking it out in the light of day and in a safe location! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #707232 19th Dec 2024 1:59pm
