Home > Maintenance & Mods (L405) > Need help with LDW wire harness
sconnell80
United States 2016 Range Rover 5.0 SC V8 Corris Grey
Gonna be retrofitting the LDW switch in my RR just for ease of turning it on and off. Have switch pack coming but it doesn’t come with full pig tail to plug into the instrument cluster. Looking for anyone that has factory or retrofitted LDW in their RR and could take a picture of the green plug that plugs into instrument cluster so I can wire mine up. Any help would be greatly appreciated. TIA
Post #706363 8th Dec 2024 2:53am
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
There is 2 types of switches. You just literally need to buy the switch that worked for you. They exist with and without green plug.i belive up to September 2015 it has only grey connection after that it has both. BTW it will work without this switch as has option in menu to switch it off and on.
Post #711636 12th Feb 2025 1:38pm
sconnell80
Yea I got the switch that works for my year and just had to change the switch plug and it worked perfect. I’ve been using it without the switch just easier to turn it off with the switch rather then going into the menu.
Post #711638 12th Feb 2025 1:41pm
