![]() | Home > Maintenance & Mods (L405) > Need help with LDW wire harness |
sgorianin@gmail.com Member Since: 11 May 2021 Location: London Posts: 27 ![]() ![]() ![]() |
There is 2 types of switches. You just literally need to buy the switch that worked for you. They exist with and without green plug.i belive up to September 2015 it has only grey connection after that it has both. BTW it will work without this switch as has option in menu to switch it off and on. |
sconnell80 Member Since: 17 Nov 2023 Location: New York Posts: 44 ![]() ![]() ![]() |
Yea I got the switch that works for my year and just had to change the switch plug and it worked perfect. I’ve been using it without the switch just easier to turn it off with the switch rather then going into the menu. |
