Home > Maintenance & Mods (L322) > Rear light problem on my 2009
disco 3.5
Hi I have water ingration in the spare wheel area which has been a problem for a number of years, I’ve taken it garage and they are saying it’s coming from the rear light area, he says my rear lights are not genuine LR part and don’t fit properly and that’s where the water is getting in, the lights look like 2012 spec on my 2009 car. Has anyone else had this problem? LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #705507 26th Nov 2024 10:31pm
p38arover
Australia
It's been a while since I've had a rear light out but seem to recall there is no opening from the rear lights into the vehicle except for the hole with a grommet for the wiring.
Just checked. I was right. See at about 1:15 on this video. So I think the mechanic is wrong.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #705519 27th Nov 2024 5:41am
JCW
Agree with above, it won’t be the rear lights, more likely than not it will be the tailgate aperture seal that needs replacing or if you have a towbar fitted, it could be the thin foam gaskets where the 8 bolts (4 each side) that pass through the body securing the crash bar behind the rear bumper. Jonathan
2007 Defender 90 XS Hardtop
Post #705522 27th Nov 2024 7:35am
disco 3.5
Thankyou for your reply’s, so glad I checked I didn’t think it was the light because the water seams to come up from panel at the bottom of the tailgate, don’t think it’s the tow bar because water builds up when it stationary, how difficult a fix is it if it’s the tailgate ? Cheers Mark LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #705526 27th Nov 2024 8:21am
JCW
Don’t discount the crashbar mounts - even when parked, rain water flows down the channels each side of the tailgate opening, then directly onto the crash bar mounts where the bolts pass through the body. Where a towbar has been fitted, this requires removing the crash bar and when re-fitting, the foam gasket can lose water tightness allowing water to creep through the bolt holes. You can seal these more effectively using something like tiger seal.
I’d suggest changing the tailgate seal first (only use a genuine one) as more often than not, that’s the culprit.
Its a pretty easy job to change, just take care to get it centralised and ensure the top left / right corners are pushed fully home before moving onto the rest of the seal. Jonathan
Post #705529 27th Nov 2024 9:06am
If you look where your computers are on the left side behind the cover you should see a clear plastic bag arrangement stuck around the rear of the stack of computers/DVD/Nav stuff etc shrouding it from water drips/ingress. Thats because JLR never could get the tailgate seal right and they preempted it leaking!... Rolling Eyes Thumbs Up
Post #705556 27th Nov 2024 2:03pm
