Home > Maintenance & Mods (L322) > Rear light problem on my 2009 |
disco 3.5 Member Since: 14 Aug 2014 Location: barton seagrave Posts: 37 |
Hi I have water ingration in the spare wheel area which has been a problem for a number of years, I’ve taken it garage and they are saying it’s coming from the rear light area, he says my rear lights are not genuine LR part and don’t fit properly and that’s where the water is getting in, the lights look like 2012 spec on my 2009 car. Has anyone else had this problem? LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
26th Nov 2024 9:31pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
It's been a while since I've had a rear light out but seem to recall there is no opening from the rear lights into the vehicle except for the hole with a grommet for the wiring.
27th Nov 2024 4:41am |
Thankyou for your reply’s, so glad I checked I didn’t think it was the light because the water seams to come up from panel at the bottom of the tailgate, don’t think it’s the tow bar because water builds up when it stationary, how difficult a fix is it if it’s the tailgate ? Cheers Mark LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
27th Nov 2024 7:21am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 876 |
Don’t discount the crashbar mounts - even when parked, rain water flows down the channels each side of the tailgate opening, then directly onto the crash bar mounts where the bolts pass through the body. Where a towbar has been fitted, this requires removing the crash bar and when re-fitting, the foam gasket can lose water tightness allowing water to creep through the bolt holes. You can seal these more effectively using something like tiger seal.
27th Nov 2024 8:06am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
If you look where your computers are on the left side behind the cover you should see a clear plastic bag arrangement stuck around the rear of the stack of computers/DVD/Nav stuff etc shrouding it from water drips/ingress. Thats because JLR never could get the tailgate seal right and they preempted it leaking!... |
27th Nov 2024 1:03pm |
