Home > Wheels & Tyres > Tyre pressures |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 |
Used some tyre chalk across the tread and go for a short drive to see how it wears 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
28th Nov 2024 3:27pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Pressures are not just about contact patch and wear. On the L322 setup the rears are higher pressures than the front which is not where you would end up if you used the chalk method. 2012 TDV8 Vogue (L322) |
29th Nov 2024 7:45am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7967 |
I just use the ones on the sticker
29th Nov 2024 9:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35450 |
on my previous 2015 the actual and recommended tyres pressures were shown in the service menu . ... - .- -.
29th Nov 2024 9:33am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 |
Thanks guys, found info on the door check! 2014 vogue se |
29th Nov 2024 11:34am |
