Home > Wheels & Tyres > Tyre pressures
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Tyre pressures
Hi guys,
Running Pirelli Scorpion Verde, 275/45/21
What’s the pressures?
Thanks 2014 vogue se
Post #705434 25th Nov 2024 8:13pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Used some tyre chalk across the tread and go for a short drive to see how it wears 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #705643 28th Nov 2024 3:27pm
JayGee
Pressures are not just about contact patch and wear. On the L322 setup the rears are higher pressures than the front which is not where you would end up if you used the chalk method. 2012 TDV8 Vogue (L322)
Post #705683 29th Nov 2024 7:45am
I just use the ones on the sticker
Post #705688 29th Nov 2024 9:10am
on my previous 2015 the actual and recommended tyres pressures were shown in the service menu . ... - .- -.
Post #705692 29th Nov 2024 9:33am
chefkenmore
Thanks guys, found info on the door check! Shocked Shocked 2014 vogue se
Post #705704 29th Nov 2024 11:34am
