Home > In Car Electronics (L405) > L405 head unit upgrade
Vogue66
United Kingdom 2016 Range Rover Vogue SDV8 Corris Grey
Hi, I have recently purchased an 2016 l405 that has the smaller type infotainment screen with the touchscreen buttons either side of the screen.
And I want to replace it with the never the wide screen all in one screen from like a 2017 if possible.
I have found a reasonable priced screen from a 2017 but I’m wondering if it’s as easy as just replacing the screen and it will work or is the software in a separate module that will need to be replaced aswell? I was hoping I could gain Apple car play aswell as I believe the newer head units have this?
I’ll try and upload a couple pictures to help clear up the changes I want.
Does anyone know if this is a simple upgrade or if I’d have to replace all of the modules or if the wiring connections are different and it won’t fit anyway. I prefer keeping it an oem look and I’m wary of the quality of the cheap aftermarket units you can get so not sure about those units.
Post #705378 25th Nov 2024 1:24am
Pretty sure it's not an option, too much is different....
AFAIK Android is the only way to go.....
Or the later, big screen but you can't reach the hazard button easily and it partially blocks the heater vents....! Pete
Post #705387 25th Nov 2024 9:03am
Pete's correct, the canbus is different from 2016 t0 2017 onwards...
loads of info about the aftermarket android screens on the forum .. Thumbs Up ... - .- -.
Post #705388 25th Nov 2024 10:17am
Vogue66
Thanks for that, that’s a shame I thought where would end up being something different.
Guess the android route would be the only way forward.
Post #705418 25th Nov 2024 4:36pm
