Home > For Sale & Wanted > [Wanted] N/S REVERSING LIGHT LENS 2003 L322 VOGUE
Speedbird209
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
Hoping there's a Santa out there who has a good N/S reversing light lens cover. Was removing mine to replace bulb and the pathetic sliver of plastic where the Philips screw goes through disintegrated. If anyone has one or can recommend a decent supplier please let me know, thanks.
Post #705140 22nd Nov 2024 2:59pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
If you have no luck on here try searching for l322 reversing light. A few come up, both used and new. You can get a pair for under £30. Probably not original equipment but I'm sure they would be fine.
I hope you get sorted. I know when I took mine out to upgrade the bulbs, one of mine separated into 2 parts, the clear lens and the grey back with bulb holder. A drop of gorilla glue sorted it. Sounds like yours was brittle or perhaps the screw was over tightened at a time.
Post #705511 26th Nov 2024 11:43pm
p38arover
Australia
N/S = LHS I assume. You'll need the whole lamp assy.
P/N XFD000053 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #705516 27th Nov 2024 5:29am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
As mentioned, if you don't have any luck I bought a set of these LED replacements and can't fault them at all, really bright which makes a nice difference:
https://www.aliexpress.com/item/1005004834...40dis!GBP!£32.12!£22.48!!!!!%40212a645f16786448136522519da822!12000030665197939!edm&edm_click_module=item_detail&tracelog=rowan&rowan_id1=aeug_edm_56672_1_en_US_2023-03-12&rowan_msg_id=7359biz_search_product:0:0_573208422$7c58ec3d142346719bef541bd7adfdc7&ck=in_edm_other
Post #705537 27th Nov 2024 10:25am
Speedbird209
Many thanks to you all for responding and advice, much appreciated !
Disintegration pretty much down to it being brittle yet the offside one came off without issue but maybe that was just down to luck. At the end of the day they're 22 years old so not a complete surprise.
I'd prefer to try and keep original but that still means a part with years under its belt so maybe a modern version will be higher quality plastic. Also like the LED option suggested as I don't have a reversing camera so more light would be advantage at night.
Once again, thanks to everyone.
Post #705549 27th Nov 2024 1:16pm
RedFL
Had the same issue and I epoxy resined a small metal washer onto the broken area of the unit. Stayed in place for months. Couldn’t tell latest as I sold the SC.
Post #705566 27th Nov 2024 4:56pm
Speedbird209
Cunning, cunning, cunning ! Why did I not think of that. Thank you.
Post #705658 28th Nov 2024 6:57pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
I went with these from Ali-Express look more OEM and are a lot brighter than both the OEM and the 3 LEDs that a lot of people go with
https://www.aliexpress.com/item/1005007574...ry_from%3A
 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #705703 29th Nov 2024 12:31pm
Speedbird209
They look realllllllly nice !
Post #705716 29th Nov 2024 4:10pm
