![]() | Home > For Sale & Wanted > [Wanted] N/S REVERSING LIGHT LENS 2003 L322 VOGUE |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 184 ![]() ![]() ![]() |
If you have no luck on here try searching for l322 reversing light. A few come up, both used and new. You can get a pair for under £30. Probably not original equipment but I'm sure they would be fine.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 ![]() ![]() |
N/S = LHS I assume. You'll need the whole lamp assy.
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 192 ![]() ![]() |
As mentioned, if you don't have any luck I bought a set of these LED replacements and can't fault them at all, really bright which makes a nice difference:
Speedbird209 Member Since: 18 Mar 2024 Location: North Yorks Posts: 12 ![]() ![]() ![]() |
Many thanks to you all for responding and advice, much appreciated !
RedFL Member Since: 13 Nov 2023 Location: Surrey Posts: 14 ![]() ![]() |
Had the same issue and I epoxy resined a small metal washer onto the broken area of the unit. Stayed in place for months. Couldn’t tell latest as I sold the SC. |
Cunning, cunning, cunning ! Why did I not think of that. Thank you. |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 68 ![]() ![]() ![]() |
I went with these from Ali-Express look more OEM and are a lot brighter than both the OEM and the 3 LEDs that a lot of people go with
They look realllllllly nice ! |
